March 26, 2011 1:16 PM PDT
I still ride an ironhead sporty. That's why 60 weight oil gets used during summer and 20-50 gets used when it's cold. While stationed in Hawaii I learned about the
Harley Davidson Chopper Oil Cooler. This link shows mine and how it works in hot big big cities like Honolulu. This summer good luck. good luck.
March 28, 2011 5:48 AM PDT
I've had a few Iron Head Sportys, I'm working on one now, my second 1979 (the bastard child).
They have a reputation for the transmission blowing apart and making a nice hole in the case.
This was caused because AMF tried to save money by removing aluminum from the "trap door", this did nothing but weaken it making it a time bomb.
To fix this you find a non 1979 "trap door" repair the case and replace the gears and such that are damaged.
What I'm getting at here is unlike the "big twins" the sportster's engine and transmission share the same oil.
Neither of these 1979's came with even a screen in the oil system, I strongly suggest adding an external oil filter, an oil cooler, and rejet your carb when adding performance exhaust pipes or mufflers.
March 28, 2011 5:56 PM PDT
Full Synthetic oil works for me and I ride all summer thru the deserts on the way to our friends house in 29 Palms. I'm using Mobil 1 20w50 right now and have for years. I'm only catching fire on the legs anymore when were at Sturgis walking the bike thru town. I'm gonna try Amsoil on my next oil change to see how the their oil works.
March 29, 2011 1:01 PM PDT
my runs between 150 and 200
April 11, 2011 6:21 AM PDT
Heat is not the enemy of your engine as much as dirty oil and improper shift positions... if you're riding around town and your RPMs are below 2,000 then you're wrong, you need to shift down and ride in a lower gear. I have seen many do this and I wonder to myself, why don't these big fancy MoCo dealerships clue their customers in? Anyway, change your oil regularly, ride in the proper gear ranges and stay on top of your maints schedule.
Run some Amsoil in your bike to cool it down some and protect your engine better.
AMSOIL Synthetic 20W-50 Motorcycle Oil (MCV) is a premium oil designed for those who demand the absolute best lubrication for their motorcycles. AMSOIL MCV is the result of extensive research, and it is specially formulated to excel in all areas unique to motorcycles, including high temperatures of air-cooled engines such as Harley Davidson® V-Twin, wet clutch lubrication, extreme pressure regions of gears and chains and rust common to short trips and storage.
AMSOIL MCV is multi-functional and fulfills the requirements of both domestic and foreign motorcycles. It outperforms other conventional and synthetic motorcycle oil.
AMSOIL, the leader in synthetic lubrication, produced the world’s first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your motorcycle.
Reduces Friction, Heat and Wear
In high heat conditions, engine protection is not sacrificed with AMSOIL Synthetic Motorcycle Oil. It has exceptional
high-temperature film strength and contains a heavy treatment of anti-wear additives to reduce wear regardless of the
operating conditions. AMSOIL 20W-50 Motorcycle Oil is thermally (heat) stable and contains maximum levels of oxidation inhibitor additives. It is extremely resistant to breakdown and engineered to prevent damaging sludge and
carbon deposits for superior engine cleanliness.
I use AMS oil too:-) Guilty!
May 27, 2011 10:55 AM PDT
Last august i bought a 2002 fat boy with 800 miles
I had all the fluids change.
i got 2500 miles on the bike now i also put a harley oil cooler on it being that i live in south fl
i want to put synthetic oil but harley said to wait until i have 5000 miles
what are your thought on this should i wait?.
thanks
jocobass
