October 19, 2011 6:57 AM PDT
Hey, if ur in a cold climate, shit happens, when you store a bike all winter. Before shuttin down for winter, its good to do two things. First drain ur fuel tank and then take your battery out and keep it on a trickle charge. Be sure your charger is an auto shut off though. Moisture in a fuel tank should not be treated with any form of stabilizer, unless, the OEM says to do it. I've seen heads and head gaskets blown by fuel additives. Moisture in your fuel tank is less troublesome than rats in your room. Be glad you have moisture.
