November 8, 2010 1:29 PM PST
                My experiance is that the new fuel is cleaner and leaves very little carbon, the engines run cleaner (leaner) and the fit of rings and bearings is closer reducing cylinder leakage and crankcase pollution of lube oil. The oils don't break down as fast and will tollerate higher temperatures causeing less oil tars. The oils do get dirty but it takes longer and is not as bad as older generation lube oils. My bike has a common engine and gearbox sump lube system so clutch wear is also fouling the oil. I seldom do short trips so cold condensation contamination of the oil is not a problem. ( Last trip to the grocery 2 blocks away took 30 miles and a cup of coffee could be 70.) I change the oil at 7500 miles or fall prestorage. The AMSOIL still is clear for the application and the filter is changed with the oil..
The Suzuki C90 engine is oil cooled by oil spray nossels in the engine and transmission that are high pressure small orficises.  No problems have been heard of by filter plugging or nossel plugs..Service calls for 3500 miles or 6 months for oil (5-30 petrolium) and 10,000 oil filter change..
